If IR915L current firmware that your device running is higher than IR9-V1.0.0.r9375.bin, then you can directly upgrade your device via *.pkg file, else you have to use .bin to upgrade.  If your  Router without WiFi function, then you can directly upgrade your IR900 series device via IR9-V1.0.0.rxxx.bin, else (P/N: XXXX-W) you have to upgrade both InRouter6XX-V2.00.rxx.bin and IR9-V1.0.0.rxxx.bin files. First step upgrade InRouter6XX-V2.00.rxx.bin not reboot, second step upgrade IR9-V1.0.0.rxxx.bin, when system install successful, Web page prompt to reboot.   Isolated upgrade Wi-Fi board use InRouter6XX-V2.00.rxx.bin,Upgrade URL: http://192.168.2.234
IR912L如何进入后台
